I've been adding URL links to all of my part database entries. According to the manual, when I select the symbol that is linked to the parts with a URL link, I should get a choice for clicking on the URL. However, I'm not getting that option. Anyone else have any luck with using URLs with their parts database?
Hi Joseph,We will investigate the issue you are facing and get back to you.Regards,Satish Saptasagar
Hello Joseph,
URLs cannot be seen in schematic drawings to click and navigate.anyhow we are checking internally.
but after adding URL to Part numbers, you can view the URLs and other information related to symbol in pdf with sticky notes as shown in below snap.
pdf publishing:- File->project publisher->under format section, you can enable sticky notes with the required field enabled.
and also you can configure the report template and get the report with URLs.sample shown below.
kindly let us know if this helps you or need more details.
