My problem is following: When launching promis.e for the first time it asks for a project database. After I select a database connection and press "add new database" button, the wizard window appears. Using it, I create new database and afterwards select it as a project database. Then the error occurs, as described in a picture. If the "ok" button is pressed, another one appears, and another one, ans so forth. This happens every promis.e launch.
Hte error says: Column "name" does not belong to table "installation".
Hi Anastasiya,For the issue you are facing can you try updating the Project Database by using the Script method, you can follow the below Wiki Link for the steps.
Didn't help. Cannot accept my password in any way. is there any other recommendation?
Hi Anastasiya,Can you try creating new Project Database using the Script Method and then check if you are facing similar issue. You can refer the below Wiki Link provided earlier for creating new Project Database using Script Method.
