Hello all,
I trying to build and publish Add-in for a and OpenUtilities Map but thy are different versions and when I build project with reference dll's from OpenUtilities Designer this `add-in` is not run on OpenUtilities Map.
In a past V8i platform when release new version of product OpenUtilities Designer , Map or PowerView they was on the same version. And add-in build on Designer runs on Map.
Any ideas way OpenUtilities Designer OpenUtilities Map are different versions and how to build Add-in on OpenUtilities Designer and runs in to OpenUtilities Map?
