The app will crash once it starts showing the crash report as shown.
This notification also pops out every time I close it.I have tried reinstalling and does not work. Is there any other way??
Hello Kiew Yung Lau, The issue you are facing might be due to MSOffice updates causing issues to Access Database Engine. Can you refer the below Wiki Link and check if it helps with your concern.
i'm experiencing issued where promis.e just crashes and closes without even displaying an error message
Hi Jay, can you try to run Promis.e CONNECT in MicroStation mode and check if you can repeat the crashing?
Thanks & RegardsSatish Saptasagar
will i lose any of the intelligent connections etc if i use this in microstation mode ?
No you will not loose the intelligence of the drawing. Also I had a question the crashing on your machine happens when loading Promis.e or while opening a page or while using any specific tool?
