good night urgent help bentley does not export anything to dgn or dwg, I work normally as it did when we had version 8 and with the update it does not work well, fix it open comms designer does not export correctly dgn, dwg or kmz has errors
when I fence and make the boom in the coax module the cbs line doesn't appear, we need that. another mistake i found when I export to kmz format I get yellow placemarks that I didn't do. FIX YOUR PROGRAM PLEASE
IS THERE ANY OTHER WAY TO OPEN THE DGN OR DWG FILES, FASTER WITHOUT HAVING TO OPEN THE OPEN COMMS DESIGNER FIRST??? IT IS VERY TAKEN AND THE PROGRAM BLOCKS WHEN OPENING AND GIVING SEARCH TO THE FILE.
Hi Oscar,
what product and version are you using? This forum is for MicroStation.
You have mentioned Comms Designer and coax module, if so please post your thread in the correct forum https://communities.bentley.com/products/communications_network_design/f/communications-forum#pifragment-27111=1
Note: If I am not wrong MicroStation is only the prerequisites pack for Bentley Coax and Comms Designer for V8i versions so Communications network teams need to see what is causing the issue. also V8i versions are not under support, you should migrate to Comms Designer CONNECT Edition
Maria Garcia
i not sure, the buttoms dont work
To find out the version in use you can go to Windows Control panel\programs and feature\ ->and search for the product OpenUtilities.or whatever product you are using.
