In the old version of Bentley OpenUtilities Designer, There is a Utilities to Export the data to WaterGems. In what version of the open Utilities Connect edition you will include this command?
There is a plan to use the WaterGEMS standard import functionality in a future CONNECT Edition release. However, this is currently not defined for a specific version. Can you elaborate on the workflow for how you currently use the Bentley OpenUtilities Designer and WaterGEMS products?
If the client has an existing water network but is not scaled, We digitize it using Bentley Open Utilities with the Bing Images attached as reference to get the exact length and location of the pipes. After we finished digitizing it, we export it into WaterGEMS. Now in the connect edition of OUD, export to WaterGEMS is no longer available. So how can we export the data we created in BOUD to WaterGEMS?
Hello Mac,
Would you log a Service Request for this inquiry and attach the DGN file so that I can take a look at the data? I can consult with the WaterGEMS team and see what the best option would be. Thanks!
Attached is the dgn file of the water network for export to WaterGems.Tandag_Pipeline.dgn
Can you confirm which OpenUtilities product and version number this file was created in?
This was created using OpenUtilities Designer CONNECT Edition Version 10.16.02.10
Thank you for the information. Can you send me your email address so that we can continue to discuss this offline?
