Bentley Water and Oracle
Hi Everyone,
I'm not sure if this is the right place to post this message, I hope it is.  I am trying to set-up Bentley Water with Oracle.  I have set-up my data model using the 'Model Administrator' and built my database schema, and everything seems to work correctly.
The problem I am having is that I cannot edit the connectivity of features once they have been posted to Oracle; and if I create a new feature, I cannot connect it to a feature that has been queried from Oracle, even if I have the lock on the feature.  The message I get at the cursor when I try to connect is 'Invalid Feature Type Selected.'.
When I query features from Oracle, the connection details are missing.
I hope someone know how I can fix this problem.
I am using Bentley Water 8.11.07.56, and I don't really want to upgrade to the new version unless I really must.
Cheers Ian
