Bentley Water - relationships between features
We recently upgraded our Bentley Water from V8i to V8i (SS1).  We had a conversion routine that was prepared by Bentley Systems.   All of these pipes, fittings, valves all nicely show the relationships when reviewed using the Feature/Edit Feature/Relationships.
However, for the first time I've added in a new main with fittings, valves, laterals and the like.  This features do not show the full list of relationishps tha tthey should.  Only what the program found while I was laying out the pipes, fittings, etc.
How do I get all of the relationships listed.  I found that I could use the edit relationship feature to add the valve to the main.  But I do not seem to be able to add additional mains to the fittings, or additional fittings and mains to the mains -- the edit relationship will change feature IDs, but not add additional additional ones.
So what do I have to do to establish all of the relationships?
