Bentley Wastewater
At Bentley.com you can find a software called  Bentley Wastewater in the product list. I would like to take a closer look at the software but I can't find it at the download section. Does any one of you know where I can find the software. Is it even still available?
Ludvig
  • Hi Ludvig,
    Bentley Wastewater has been replaced by Bentley Utilities Designer, which will shortly be released. If you would like to try an early adopter version, this is available on the SELECTservices download site. Filter by Product Line = 'Utility Network Analysis and Design', and Download Category = 'Beta and Work in Progress'.
    Hope that helps,
    Mike
    This is a test
