Bentley Communities
Site
Search
User
Site
Search
User
Product Communities
OpenUtilities
OpenUtilities Substation | Promis.e Forum
READ FIRST: Forum best practices
Sign In
Locked
Locked
Replies
Subscribers
29 subscribers
Views
Users
0 members are here
Offline
Matt_P
over 8 years ago
When posting a question or discussion topic on the forum, please include the name of the product you are asking about
Promis.e
Bentley Substation
Bentley Raceway and Cable Management, or abbreviated as BRCM
Instrumentation and Wiring, or abbreviated as I&W
and the product's xx.xx.xx.xxx version number, such as 08.11.13.140 or 10.01.00.23. The version number is typically found in a
Help > About
menu within the software.
Find the About Promis.e dialog
Find the About Bentley Substation dialog
Find the About Bentley Raceway and Cable Management dialog
To eliminate the need to remember to do this, and eliminate additional questions when you forget, you can add this information to your Bentley Communities signature. To create or modify your signature, sign in then click your avatar in the upper right and select
Settings
Before posting in the forum, please use the Search box to see if your question has already been asked or if there is an article that addresses it.
If you find a forum thread or wiki article and the answer provided there works for you too, click the
This Helped Me
link on the answer post or article.
If you know the answer to someone else's question or issue on the forum, feel free to answer!
If you are the original poster and somebody suggests an answer to your question and it answers your question or resolves your issue, click the
Verify Answer
button on the answer post. See example below.
See also
Communities forums best practices and tips
