After i press ok, the left side plane shows only few project. Actually more projects are there in the database. If i do search i can able to see the project but not on the project manager. Please do the needful to fix this issue.
Hi venkatesan, is this promis.e or Bentley Substation? What version (see Help > About)?
What preceded this problem? Have you just upgraded or switched platforms?
For future searching purposes, the error message is:
Internal ErrorError Message: Object reference not set to an instance of an object.TargetSite: Void UpdateProjectOptionXmlToNewVersion(System.String)DeclaringType: ECT.ECAD.UI.Options.ProjectOptionsAttributes: private staticMemberType: Method
