Insert cable command is very convienient when trying to insert a straight cable with some natural sag. However when trying to draw cable that could wrap around a piece of steel, grounding cable, there is no way to control where the cable goes. In MS we could use a b spline which let us add as many vertiices as we needed. Is there some way to do this in Bentley Substation?
