API builder: Macro rotate
We have been experimenting with the API builder and like it for the most part.  We have come up with a way to generate the spreadsheet needed to feed Bentley Substation.  There is a command missing though.  Rotate macro is not available within the API builder as far as we can see.  This would be useful so we do not have to make a macro for every conceivable angle.  There is a command for rotate symbol within API and there is a command for rotate macro within BSUB, but not within the API builder.  Any suggestions?
