How can I turn off the Advanced Routing on SS7? The help file states I should be able to type in ADVANCEROUTING to toggle it on and off but Autocad doesn't recognize that as a command. I believe the release notes mentioned something about changing the at.ini file, I would like more details on that, if that is indeed possible.
Stephen Wood-Davies
Senior Designer / Bentley CAD Administrator
Answer Verified By: AHolfeld
