I would like to add a new custom label within parts database manager for "Heat Loss", and then assign my part a heat loss based in watts so I can generate a report and calculate the complete heat loss.
I've looked at editing the user interface but cannot see anywhere that would allow a custom label to be added. Is this possible?
The thread posted by Matt_P here: suggests this can be edited by right clicking the item, but I cant see any menu after right clicking, so wondering if the function has been removed?http://communities.bentley.com/products/electrical___instrumentation/f/275806/t/119099
You have to create the custom attribute first
This is done through the creation of symbols, you can add an attribute in that dialog box. Once you add an attribute you can back out of the symbol creation and your attribute will remain.
View the images below, as I created a "heat loss" attribute to my database through the symbol creation, backed out of the symbol creation then went into a project and could apply that custom attribute to any promis.e symbol afterwards.
Then once this is created you can add it to any symbol by right clicking to view the text attributes through "symbol text"
Bentley Software utilized: Promis.e v.08.11.13.57, ProjectWise v.10.00.01.67, MicroStation v.08.11.09.536
Parts Database Manager is no problem, I use custom attributes in mine all the time. I have never tried reporting one, and I can't seem to find it on through an itemized part report, but if it isn't available, you would have to generate a report based on an SQL query instead of modifying an existing report. Unless this can be scripted using C#, I haven't tried this.
Database image:
