I'm not sure that my question is even worded totally right (another post late in the day :-/) but... what I'm trying to achieve is to combine two 3D model dgns into one, and not lose all the linkages between my construction drawings and my saved views/section cuts/references. So I'm thinking the models box then using "import models" would be a good place to start. But another concern I had was that I didn't see a way to have both models be visible in the main default model while still being able to toggle the visibility on and off like you can in the references box. Any help or suggestions? Thanks.
Jeff Getch
Using Bentley Substation V8i SS7 v.- 08.11.12.137
