How to do 3D substation using Bentley substation from 2d raster image? Please help. I already insert the dwg. to the software, but I don't know how to place the reference point onto the dwg.file. I also find it very difficult to find the symbols for the isolator.
2. How about the rod for the grounding grid? I'm not sure on how to insert the grounding rod. is it will be placed automatically?
3. When inserting the structure, does it need a base like the transformer?
Hope for a asap reply. Thanks .
Unknown said:How to do 3D substation using Bentley substation from 2d raster image? Please help. I already insert the dwg. to the software, but I don't know how to place the reference point onto the dwg.file.
Are you referring to the Project Reference Point (PRP)? If so, select 3D Layout Design > Manage Project Reference Point then click the Help button on the resulting Project Reference Point dialog.
Unknown said: I also find it very difficult to find the symbols for the isolator.
You could try selecting 3D Layout Design > Insert Substation Objects, set the Part Type to "Single", and add a filter like [Detailed_Description1] Contains switch, then Apply Filter
Unknown said:2. How about the rod for the grounding grid? I'm not sure on how to insert the grounding rod. is it will be placed automatically?
In Bentley Substation V8i SELECTseries 8, grounding rods can be placed using the 3D Layout Design > Insert Rod Object tool or inserted automatically when the grounding grid is drawn using the Place Grounding Grid and Segments tool.
Unknown said:3. When inserting the structure, does it need a base like the transformer?
This is really a question of design principles. Bentley Substation does not require a base to be placed for you to place a structure, but I would think there would normally be some kind of foundation under a structure in the design. Note: I am not a substation design expert.
Dear @matt_p thanks for your help. I just completed inserting the symbols.
We have no CAD team on creating symbol for 3D model out of the equipment. I am trying to create a proof of concept using Bentley Substation as I want to see how the features will work & what if I convert it in 3D.
ME: Ok, so try to chose equipment from Bentley catalogs, that is close to what you need.
I use the scale as per suggest by you. There is a prompt message to choose the dimension to be in metres or mm. Please advise.
ME: Sounds like you are trying to start with an existing DWG or AutoCAD file, an you receive that prompt, yes? Keep things simple and choose meters. Then make sure your master units are set to meters.
I tried to copy the previous symbol inserted, when I paste it, I can see that the object is either floating / sit below the ground. I already use DTM mode . At the end, I had to move the subject to the ground using the copy/paste/move feature. Isn't the equipment suppose to follow the DTM attached ?
ME: If you using DTM, then try to insert all similar components rather than copy. If you use copy - and your DTM is a basic flat surface, make sure to choose DTM and "Lock Height" in tool settings.
