In the Terminal/Pin-Plug Manager (latest AutoCad Promis-e V8i) if I select all 15 terminals then in the left pane Properties, I click on Part Number(s) and assign a part, the Part Number column shows the correct part number....so far so good........but when I click on an individual terminal in that column and check the part number, only the part number and quantity show with all the other columns blank. I have tried with various different part numbers but still the same, I have tried a re-boot etc.
Any ideas,
Nigel.
Matt,
Thank you.
I saw terminal blocks appear when the Devices radio button was selected on the Insert Symbol By Device ID dialog in one other case. In that case using Replace Symbol to replace the schematic terminal block symbol with itself throughout the project resolved the problem. But that case involved a promis.e 2007 v2.0 project that was brought into v3.0.
I don't recall that all the fields except the part number field appeared blank when going back into Select Part Number in that case, but that is not normal and I do not see that behavior now.
When assigning a part number to multiple terminal blocks, I usually just highlight the terminal blocks in the Terminal Manager and then click the # toobar button or go to Assign>Part Number. But I can't say assigning part numbers on the Properties tab in Terminal Manager has anything to do with the problem.
