Dear Sir!
I readed help about " creat macro" . :Select the Group Terminals checkbox if you wish any terminals in the macro to keep their current terminal numbers when the macro is placed.. When creat a macro , I selected "Group Terminals". But when I insert symbol by " insert macro" . Terminal block of macro was automatically change Name Tag, Number of Terminal Block.
I do not know why they are be changed,. Please help me!
My purpose is : tag and number of Terminal block of macro is not changed when I insert them to drawing . Only intallation, location of terminal can change according requirement.
Please give me solution to perform my purpose!
Thank sir!
Hello Huong, while placing Macro there is a macro setting at bottom, please select all the option ( refer the below image)After placing the macro, there is option that you can change the terminal number and tag as you want.
Answer Verified By: Huong Nguyen
Thank you for this reply. I was having the same problem as Huong after reading the help information.
I appreciate it
Jess
