Dear Sir!
I want show : function text, target of symbol connect to terminal/plug at Graphical Plan.
I inserted : TC_<Target_ID>, TC_<Target_AttFUNCTION> as picture:
But when I run report : Graphical plan. it only show as below picture.
I don't know how I setting to appear at Form column: Tag.Connect point and Fun.text column : Function text of symbol connect to terminal/plug
Please help me!
I send to you my graphical plan which used to report
ACIT1212.Dwg
Hi Huong. To see connection point text along with the device tag of the target device, use the TC_<Target_ID> variable. You mentioned that you inserted this variable, but your template contains TC_<Target_Tag> instead.
If you are using the out-of-the-box Function Text attribute on your schematic, then the variable to use for that would be TC_<Target_AttFunctionText>.
I insteaded TC_(Target_ID) , But the
Matt_P said:If you are using the out-of-the-box Function Text attribute on your schematic, then the variable to use for that would be TC_<Target_AttFunctionText>
I use FUNCTION attribute , So I use TC_<Target_AttFUNCTION>.
But the result is not diffirent as the picture which I sent to previous post,
Huong, is the TC_<Target_ID> variable working to show the tag and connection point text?
Please post a screen shot of the Specify Attributes step of Create Symbol. Make sure the row for the FUNCTION attribute is visible in the screen shot. For example, in the screen shot below you can see the Function Text attribute.
Please also post another screen shot of your updated graphical plan template.
