We've had a recurring incident where all wire links have automatically renumbered themselves back to the default tags Lxx. This is happened to the same user before on another project. Other uses have also reported similar behavior.
We typically tag these as 24V+A1, 24V+A2 etc.
Ive confirmed with the user that no pages have been moved or copy and no renumbering (re sequence IDs) has taken place, this has just randomly happened.
Bringing up the "Resequence Wire Link" window, shows Wire Link L19 has wire 919487 connected, however in the background you'll see it has wire 102 connected.
Is anyone able to offer any information on what might be causing this?
I've uploaded a backup of the project to:
https://www.bridgesltd.co.uk/BASINGSTOKE%20BMS%20SYSTEM.Prj
Kind Regards
I can confirm that I have also downloaded and succesfully restored Adam's project. It's PRJ file.
Best regards, Wojtek
SW: Promis.e 08.11.13.96/23.00.00.46
Hi Adam,We tried to download this project several time but its in 7 zip file.
If it possible can you share your project back up in link that we provide you.
Link to upload project:- https://bentley.sharefile.com/r-r5c2b3a9c11745109Regards,
Avanti Khandalkar
All done, many thanks
Hi Avanti Khandalkar, have you had a chance to look at this?
Hi Adam,
We are not able recreate the concern that you are getting. As you mentioned that the "Resequence Wire Link" window, shows Wire Link L19 has wire 919487 connected, however in the background you'll see it has wire 102 connected .Please let me now how you are doing this all procedure.If we add ( copy or move) any pages you need to do Resequence Wire link.
So we need to know the Procedure.Sorry for late reply.Regards,
