I am getting this error message when i run the promis.e V8i (SS8). Project Manager shows up without any projects on the folder view. I have cleared the App data content and also replaced the project, system and user options.xml files. Still getting the same error message.
Hi Vankatesan,Can you share the screen shot of your project manager, Also do you get the Error Message after launching Promis.e or while opening any Project ?Also you can try Reset Project Manager dialog, you can follow the below Wiki Link for resetting the dialog.Regards,Satish Saptasagar
I get this error message when i launch promis.e, i tried reset button on the project manager dialog that too doesn't help me.
Hello Venkatesan,Please check System paths in the Setup dialog and in this Dialog there is data folder path, verify whether you have given proper data folder path or not
If not then please give proper path , it might help you to resolve your concern.Regards,
Avanti Khandalkar
