in a project there's a lot o cables, each of them has attribute "Length" properly filled:
How to generate report, calculating total cable lenght for each part number?
Regards, Wojtek
Hi WojtekM,We will investigate your concern and will provide you an update.
Hi, any news in that case?
Best regards, Wojtek
SW: Promis.e 08.11.13.96/23.00.00.46
Hi Wojtek,There is no direct report template available that would calculate the total length of the cable.However , the report can be customized by running a SQL query.Go to Manage>> Template Management>>Report Template DesignerIn the new report template you can customize the same through a SQL statement.All customizations can be done by running a custom SQL query.Hope this helps.
