Hi all,
is it possible to migrate DGN files made with EED (Elementary Electrical Diagrams) to Promis.e?
Can Promis.e read these kind of files?
Thanks in advance for the answers.
Hi ,Yes , it is possible to migrate DGN files made with EED to Promis.e.For the same you need to import the file into Promis.eGo To File >> Import.Promis.e can read .DGN files.Hope this helps.Thanks.
Hi. Thank you for your quick reply. My concern is not about the file type (DGN is a standard for MicroStation) but the graphic/data structures used by EED such as ASID, Data Linkage, etc...
Hi We will have to investigate the concern and will provide you an update accordingly.Thanks
Hi Iron,Can you please share your EED ( Elementary Electrical Diagrams) file.
We need to check on our side.Regards,
Avanti Khandalkar
Hi, thank you for your response.
You can find an example of EED file attached.
I also upload a screenshot that shows you an EED element information (with User Data Linkage, Dependency Linkages, RIS Data Linkage).
All EED elements of a Bentley Elementary Electrical Diagrams design file have a unique ID called ASID.We use EED functions like eedApi_getEEDDataEx to retrieve ASIDs.
I need to know if Promis.e can read EED element data like ASID, MSLINK, etc...
We have a custom Oracle database where we store components data. In database every component is identified by MSLINK.
TEST_EED.dgn
