When I start any project in Promis.e I am getting this error:
Text from LastError.txt:
Void RestoreCatalogPaths(Bentley.DgnPlatformNET.ConfigurationVariableLevel): Object reference not set to an instance of an object.0: at ECT.ECAD.API.WorksetConfig.RestoreCatalogPaths(ConfigurationVariableLevel level)1: at ECT.ECAD.API.WorksetConfig.Restore(Boolean isWorkspaceConfig)2: at ECT.ECAD.API.SystemSetup.RestoreNodeFromVariable(XmlDocument doc)3: at ECT.ECAD.API.SystemSetup.Restore()4: at ECT.ECAD.API.SystemSetup..ctor()5: at ECT.ECAD.API.SystemSetup.Recreate()6: at Bentley.Electrical.UI.Command.CommandEntryServiceBase.Init(Int32 hwndMode, Int32 hwndLayer)
Any idea what to change?
Hi Satish,
I am using local configuration.
From irregular things during installation: Due to issues with ARM on my computer I had to install Windows Server separately.
Thanks!
Krzysztof
