I'm trying to fill in some huge gaps in my knowledge of Promis.e using the resources at learn.bentley.com.
Looking at the download that comes with Promis.e CONNECT Edition Fundamentals (Metric)
you get the following files
I understand the concept of working along with the pdf to go through the fundmentals, however there is no guidance regarding the datasets / parts database. How are they used?
Following though with the PDF I very quickly reach a point where an option I'm requred to select are greyed out, preventing any progress. I'm unsure if it my lack of knowledge or an issue with my setup.
See family option greyed out here;
I'd also like to know how the assesment part of the OnDemand courses work.
Clicking on that option only brings up a window that says "Skills assesment" and nothing else.
Also, pointers towards any other online resources for learning some of the fundamentals of promis.e would be appreciated.
DM
Hi Doug,You can refer the Promis.e Help file for Promis.e Wiki for using the datasets / Parts database. The Dataset mostly contain Project or catalogs they need to restored or imported in Promis.e, catalogs will contain existing symbols that can be using in a Project. Parts Database has details for Part Numbers. Below are some Wiki Links and Help links that can help with your concern.
Doug Murray said:I understand the concept of working along with the pdf to go through the fundmentals, however there is no guidance regarding the datasets / parts database. How are they used?
Import catalog
How to add Parts database
Can you confirm if the by clicking the Device usage chart in the Device Properties dialog and check if the ID is listed as Duplicate ID.
Doug Murray said:Following though with the PDF I very quickly reach a point where an option I'm requred to select are greyed out, preventing any progress. I'm unsure if it my lack of knowledge or an issue with my setup
Regards,Satish Saptasagar
Hello Doug,
the reason for family option grayed out, it might be you are trying to place Equipment symbol for which family concept does not work. symbols like transformers, motors .etc
it will work only for the switches, fuses, contactors which have additional inbuilt secondary components.
please let us know the symbol name for which you are getting family option grayed out.
Sid
Thanks Satish,
Once I'd Imported the catalogue and added the parts database I was able to work through the fundamentals pdf successfully.
The issue with te symbol family was resolved.
After I'd added the parts database I had two catalogues to choose from, which is great for working though the LEARN material
I would now like to add everything from our V8i parts database to our Connect edition database.
Is there a way to merge two parts databases within Promis.e Connect edition?
Promis•e CONNECT Edition Update 10
See above post.
Any guidance on how the assesments work on the Learn server?
Clicking the "Assesment" text on the right of that screen creates the following window;
Please advice how to proceed with the assesment.
