When I start project publisher it will run for a few seconds then shuts down Promis.e Connect completely
Hello Alan,
can you please let us know the version number(update 1,update2..?) of Promis.e connect which you are using.
does this issue occur for a particular project or for all the projects?
Sid
I am using Promis.e Connect Edition Update 2 - Version 10.02.00.29
It happens on all projects
Answer Verified By: Alan Paquette
ok. do you get any error messages or popups when it crashes?
no it just shuts down completely
just wanted to verify in your machine. do you find files in this below location.
C:\Program Files\Bentley\Promise CONNECT Edition\Promise\Electrical\plugins\ProjectPublisher
and ,C:\ProgramData\Bentley\Promise CONNECT Edition\Configuration\Datasets\Promise\Plugins\ProjectPublisher
kindly send a snapshots of the above folders.
