In promise for autocad you would add the catalog paths from project manager, setup. Where do I add catalog paths in Standalone package. From the catalog manager what edit mode do I choose or is there another place to add the new path?
Hello Imp,In Promis.e CONNECT you can add Catalog Path which contains all the Catalogs from the Modify Catalog Path dialog as seen in your screen shot.You need to select Edit Mode as "Overwrite" and in Value provide the path of folder where all you Catalogs are located. After which Promis.e will list the Catalogs in the folder as seen in below image Catalog Path.Hope the above suggestion helps with the issue you are facing.Regards,Satish Saptasagar
I am getting an error message when I click the configuration variables.
Hi Lisa,Have you tried relaunching the Promis.e ? Did the issue come up when you tried to save any settings in Configuration Variables ?Regards,Satish Saptasagar
Hello Satish
I have relaunched the software several times and also restarted the computer. I error occured when I noticed there were no symbols in the symbol library and then tried to go to the configuration tool to check the catalog path.
