In the catalog manager the tool to convert between autocad and MS is greyed out. How can I convert my autocad symbol library to Microstation connect edition.
Hi Imp,We would like to know which version of Promis.e are you trying to use to migrate the Catalog / Projects. Also which is the version of Promis.e you are currently using / in which version of Promis.e the Catalogs / Projects you are trying to migrate are created ?Regards,Satish Saptasagar
Hi Imp,
I can see that you are using Promis.e SS6 08.11.11.18 your need to use Promis.e SS7 08.11.12.137 for migration of Projects as this feature. Below is Wiki Link for Migration Tips and Tricks. Promis.e CONNECT update 4 cannot be used for migration of Projects & Catalogs from Promis.e SS6.
Also you can try and check to take backup of Projects and Catalogs and check if you are able to save them in Microstation format..
Hope the above details help.Regards,Satish Saptasagar
