Hello! I'm a novice Substation user. I need help adding a 3d model of dwg format. Also need help in the sequence of actions. If you have a substation template, I will be grateful to you. Since my templates are deleted.
Hello Sergey,
Can you confirm that you need help to convert Dwg 3d model to Dgn? Do you want to know the workflow of How to convert DWG to Dgn?
Can you let me know which version of the software you are using?
Avanti Khandalkar
Answer Verified By: Sergey Kozhin
I am using version 10 of Update 2.
A substation template is required. Also need to convert dwg format.
Hi Sergey,
To Convert Dwg format, you can follow the below steps
You will get Substation template in the below link,
We are not sure you need a template or title block, can you confirm are you creating a new page in a substation ?
Send me a template, please.
