Hi
I have promis.e installed and a project ready. But how do I get my rsalg file into the project?
Hi Lennart,To open a RsAlg file in Promis.e you need to have Rail Signaling Plugin installed. can you confirm if you are using Promis.e with Rail signalling.Regards,Satish Saptasagar
Hi Satish. Yes I have the signalling expansion installed
Hi Lennart,
Open one model in the project and select Project Settings (S1), top-left control is where you define the RsAlg. Please note that you also need a 3D model of the centerline from BRT. That one should be attached as a reference. In Project Settings (S1), top-right control you can select the centerline.
Answer Verified By: Lennart Popp
Thanks Hakan. Is the 3D model of the centerline from bentley rail track a .dgn format file?
