How do I show text and dimensions etc over the top of a referenced saved view?
I am using Substation Connect V6 and I am trying to place text, dimensions & identifiers onto a Saved View that I have referenced into a construction sheet.
(The saved view was created in the model and then referenced into the construction sheet)
BUT, whenever I place either text or dimensions etc they end up behind the reference and you can not see them.
I have changed the priorities of the items and it still makes no difference.
I am unable to find whether I can change the priority of the saved view when referenced in???
When I reference in the image as a normal reference the text, dimensions etc all work fine and are visible on top of the reference so we can see them.
(See below)
