Hello! Help me find this in Promis.e version 10
Hi Anastasiya,The option you are referring in the above image is Insert Balloon Command. You can access it in Promis.e CONNECT from Panel Design >> Components and Insert Balloon.
Hope this helps for the issue you are facing.
Tell me the sequence of actions with this button, please.
