Hi All,
Hope you can help.
We have been using the Promis-e software since 1995. We have used the Promis-e standard project setup since the beginning =Installation+Location-Device.
Our parent company wants us to change from this standard method to =Function+Location-Device and keeps quoting IEC 81346-2 2019 for the change.
Does anyone know where the '=Installation+Location-Device' methodology comes from or if it is referenced in an EN/IEC standard.
Hello Nigel,Can you please explain Project Setup is =Installation+Location-Device means? Are you referring to device ID or Project Option setting.Function attributes come in the Symbol but you mention project setup.
Please clarify.
Avanti Khandalkar
Hi Avanti,
On Promis-e drawing boarder you have = & +
You then have device: - In the case below (-5050-E1)
So in the example above it can be said -5050-E1 is =DESK+CUBICLE-5050-E1. (=Installation+Location-Device)
This methodology has been incorporated in our drawings since 1995 where it is mentioned in the original ECT Promis-e documentation and program:
I would like to know which EN standard this concept followed.
Hi Nigel,Can you tell me which version of the software you using?
We use V5.05 & V8i Version 08.11.13.96. Screen shots are from V5.05
Hi Nigel,First, you showed me the Title block image which can be changed from title block designer
And the second image of Symbol Device ID.You can edit it the format of the Device ID,Option ->Project option -> Display format -> Device ID format
you can try these steps and let us know whether this works for you or not.
