How do I add more columns from the database in the part number search window? for instance my user columns do not appear
Hi Larry,You can add the required Column for filtering the Part Number by using editing the Parts Database Path and specifying the Variables for the Column while Creating or Editing the Parts Database path. You can refer the below image for details where I have highlighted the User1 Column and you can edit you parts database column details according to your requirement. Also you can refer the below provided Wiki Link which describes how to create new Parts Database Path which will be helpful for you in understanding how to edit the parts database.
HTHRegards,Satish Saptasagar
Answer Verified By: Larry Baker
THANKS MUCH APPRECIATED!
