I have error message as follows:
System.Xml.XmlNode ImportNodeInternal(System.Xml.XmlNode, Boolean): Cannot import a null node.0: at System.Xml.XmlDocument.ImportNodeInternal(XmlNode node, Boolean deep)1: at ECT.ECAD.API.SystemSetup.RestoreNodeFromVariableParts(WorksetConfig worksetConfig, XmlNode configNode)2: at ECT.ECAD.API.SystemSetup.RestoreNodeFromVariable(XmlDocument doc)3: at ECT.ECAD.API.SystemSetup.Restore()4: at ECT.ECAD.API.SystemSetup..ctor()5: at ECT.ECAD.API.SystemSetup.Recreate()6: at Bentley.Electrical.UI.Command.CommandEntryServiceBase.Init(Int32 hwndMode, Int32 hwndLayer)
Hi Vineethkumar,Can you let me know when do you get this Error Message, if you can provide the Work Flow or the command followed that results in Error Message ?Regards,Satish Saptasagar
while opening the Promise connect edition, this error came. same kind of errors coming while opening. its coming after updating path in the "configuration variants" below mentioned screen shot.
Also note that in my system while moving symbols (Parent symbol) all its parameters are not moving together.
Also for some symbols, while show/hide cross references, its not working
Please go through the above points
Hi Vineethkumar,Can you confirm if Promis.e was working normally before changing the configuration to the D: path as shown in the above screen shot ?Also is the D: a local drive or is it on network location ??Regards,Satish Saptasagar
the new version we installed before 5 days and we were updating other setup, it was working and we didn't update this database at that time..
D is a local drive, not network
Which is the current version of Promis.e and the earlier version of Promis.e ?Can you try assigning the attributes in the configuration variables for all the variables again again and check if it works ?
