When I insert a new/existing child for a parent, the child not showing cross reference but parent showing it. And show/hide cross reference is not working also for. Both the same error is not available for colleagues.
Hi Sharook,
Can you confirm that have you placed proper family and device Id for the child symbol?
For example:- I placed parent symbol as CR253 with family O10
then in the parent cross-reference symbol is showing below result,
Please let me know are getting any error message or warning.
Avanti Khandalkar
Good morning Avanti,
I am sure I have placed proper family & device id, but not getting cross-reference for child.
As per your mail the below option not working for me.
Are you using default /out of box family or custom-created by you.
as a suggestion, can you please check in the family for cross-reference is there any symbol assigned or not. also, you can verify in the symbol creation wizard whether cross-reference attributes are placed or not, for that particular symbol.
Sid
Hi Sharook,Can you confirm whether you are facing this concern particularly for one project or you observe this concern in every project?Looking for your update.
Avanti
Dear,
Not only for one project but also for all project. See the attached photos to understand the problem deeply. Now when I insert child part number also showing with that symbol (See the attached).
