Hai,
The below attached is from MicroStation. How can we get the same in Promise (Red marked shortcuts not available in promise).
HI,Please follow the below image,
Avanti Khandalkar
We already using ELECTRICAL as shown below.
Try PositionMapping: https://communities.bentley.com/other/old_site_member_blogs/peer_blogs/b/marc_thomass_blog/posts/connect-edition-using-position-mapping-to-get-to-tools-really-quickly
you'll get keyboard shortcuts for each Ribbon group.
But I am not sure if electrical tools are available in Task Navigation scheme.
Best regards, Wojtek
SW: Promis.e 08.11.13.96/23.00.00.46
Hi Sharook,You can use F2 button to display the Mapping to select command and navigate through the Ribbon.
Hope this helps !!Regards,Satish Saptasagar
