After changing save options profile as shown in below screen, I am unable to modify project, modify symbol and I can't restore new projects as well. An error message occurs while opening promis.e. and its showing while opening any sheets.
defaut location : C:\ProgramData\Bentley\Promise CONNECT Edition\Configuration\WorkSpaces\Promise IEC Example\Standards\Promise\Config\Options
changed location : D:\Promise CONNECT Edition\Config\Options
Error message
Void .ctor(Bentley.Electrical.UI.General.CommandCarrier, Boolean): Object reference not set to an instance of an object.0: at Bentley.Electrical.UI.Wizard.DWorksetConfig..ctor(CommandCarrier commandCarrier, Boolean isNew)1: at Bentley.Electrical.UI.Command.Command.ModifyProject(String fullpath)
Pls look into this issue
Hi Vineethkumar, According to the discussion in meeting last week has the RAM on your machine been increased to Minimum Required 16 GB according to the minimum requirements in below Wiki Link ?
Regards,Satish Saptasagar
