Hello
I have been getting this Error when trying to use Bentley substation connection
error text
Void RestoreCatalogPaths(Bentley.DgnPlatformNET.ConfigurationVariableLevel): Object reference not set to an instance of an object.0: at ECT.ECAD.API.WorksetConfig.RestoreCatalogPaths(ConfigurationVariableLevel level)1: at ECT.ECAD.API.WorksetConfig.Restore(Boolean isWorkspaceConfig)2: at ECT.ECAD.API.SystemSetup.RestoreNodeFromVariable(XmlDocument doc)3: at ECT.ECAD.API.SystemSetup.Restore()4: at ECT.ECAD.API.SystemSetup..ctor()5: at ECT.ECAD.API.SystemSetup.Recreate()6: at Bentley.Electrical.UI.Command.CommandEntryServiceBase.Init(Int32 hwndMode, Int32 hwndLayer)
Hi Shaban,Can you tell me when are you getting this error?
Avanti Khandalkar
Hi
I get this Error when I start Bentley substation and it prevent me from opening project management tool explorer open
and all I get is the page open with no tools ribbon see screen shots
If you could help on resolving this issue please let me know
Hi Shaban,for the issue you are facing can you try check if your machine meets minimum requirements according to the below Wiki Link ?
Also check the compatibility of the software according to below Wiki Link.
I would also like to know which version of Substation are you using ? And if its a new installation or if Substation was working fine and you suddenly started facing this issue ?Looking forward for your update. Regards,Satish Saptasagar
HI thanks for the answer
yes my computer meets minimum requirements see attached screen shot
I would also like to know which version of Substation are you using ? I am using Bentley Substation CONNECT Edition 10.03.00.042
yes the Bentley was working fine for few weeks and then this came up
Hi Shaban,Can you try following the suggestion in below Wiki Link and check if it helps with the issue you are facing ?
