When in a oneline drawing, I select “INSERT SYMBOL” (Electrical >2D Design > Components > Insert Symbol.
When I do that I get the following Error Messages:
DeviceDB Error Message: Object reference not set to an instance of an object.
TargetSite: Boolean InitRepository()
Declaring Type: CCIntegration.CCSubstationRepository
Attributes: private
Member Type: Method
Stack Trace: C:\PRogramData\Bentley\OpenUtilities Substation CONNECT
Edition\Configuration\Datasets\Substation\Config\LastError.txt
I hit Ok and then I get another error message:
UI Error Message: Exception has been thrown by the target of an invocation
TargetSite: System.Object.InvokeMethod(System.Object[], System.Signature/Boolean)
Any help would be appreciated.
Hi Paul,Are you facing the issue with all the symbols from different catalog or is it related to a particular Catalog ?Can you try to do Rebuild Catalog and check if it helps ? you can refer the below Wiki Link for the steps.
Kindly let us know if the above suggestion helps with the issue you are facing. Regards,Satish Saptasagar
Hi Satish,
It is all. I went through your rebuilt suggestion. No change, still having the same issue.
Hi Paul,You can try renaming the Per User App data folder and check if it help ? You can refer the below Wiki Link for location of per user App Data Folder.
Hope this helps!!Regards,Satish Saptasagar
