Hello everybody!I have an error: Conversion from varchar data type to datatime data type resulted in out of range. The execution of this instruction has been interrupted.Promise is integrated with Project Wise, a new project database is created and Promise is reinstalled after an error occurs. Did not help.
Hi Pavel,We would like to know when do you get this Error Message ? Do you get this while launching Promis.e or while using a particular command in Promis.e ? Also are you using Promis.e CONNECT with ProjectWise with Managed WorkSpace ? Regards,Satish Saptasagar
Hi, Satish!
The message appears when trying to return a sheet ("check in"). Apart from this error, nothing critical happens. And I am using Promis.e CONNECT with ProjectWise with Managed WorkSpace.Thank you)
Pavel,Is this issue only happing on your machine or is it happing with all the user using Promis.e ?Can you confirm the version of ProjectWise that you are using ? I can see that you are currently running Promis.e CE Update 4 on your machine.Regards,Satish Saptasagar
Hello Satish!
The problem occurs for everyone who uses PromisE on this server.
ProjectWise 10.00.03.280
The error did not appear immediately, but after some manipulations with the project databases.
Reinstallation of the project databases gave no results.Regards, Pavel Shemelin
Hi Pavel,Can you provide details on what manipulation was done with database ? Did you modify some data in Project Database for Promis.e or some other changes were made ?Regards,Satish Saptasagar
