Currently using Promise CE 10.06.00.52 and it appears to be not inserting our customer logos within any borders when adding a new page only. If a page is copied or the project is restored the logos displays correctly.
Note, almost all our borders have been carried over from V8i.
This bug appears to apply to all our borders.
We've tried re-adding the logo within Connect Edition (title block designer), it places the logo correctly, displays correctly, saves correctly, however when adding a new page the logo is blank (just a white box).
Is this a known bug?
Is it a raster logo or vector one? If it's a raster one, it might be an issue with path to raster - try to copy raster file directly to project's path.
Regards, Wojtek
Raster logo, but they're not paths, they're pasted / inserted via paint.
Can you try key-in raster display on ?
Hi WojtekM, could you confirm where this setting is?
