Good day!
Problem: I created a new drawing mode, but the display settings for the symbol text do not work for me.
What did I do:
1.I have created a new column in the parts database file.
2. Mapped database fields
3. Defined the program behavior for this type of drawing in Mode Manager.
4. Checked that the required line appeared in the Multi_Language_UI.mdb file.
5. A line with a new mode has appeared in the display format settings.
6. When trying to change the display option of a tag...
7. ... the display of the tag in the drawing does not change (the sign in front of the device tag does not disappear).
8. What have I done wrong or what have I not done?
Thank's.
HI Pavel,Have you tried to update page after changing in device tag format?
Please try this and let me know the device tag changed or not
Regards,Avanti Khandalkar
Hi, Avanti!
I tried refreshing the page, no changes happened. I also noticed that the device tag changes if I change the settings in Schematic mode, although I have Power Supply mode set. Perhaps this is a bug, or perhaps it is necessary to register a new mode somewhere in the project database. True, I do not know which of the SQL tables stores data on drawing modes.
