After Installing newest 10.06.00.52 version of Promise Connect edition I am getting the following…
Void EmulateFileIOPermissionChecks(System.String): The given path's format is not supported.
0: at System.Security.Permissions.FileIOPermission.EmulateFileIOPermissionChecks(String fullPath)
1: at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
2: at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize)
3: at System.Xml.XmlDownloadManager.GetStream(Uri uri, ICredentials credentials, IWebProxy proxy, RequestCachePolicy cachePolicy)
4: at System.Xml.XmlUrlResolver.GetEntity(Uri absoluteUri, String role, Type ofObjectToReturn)
5: at System.Xml.XmlTextReaderImpl.OpenUrlDelegate(Object xmlResolver)
6: at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
7: at System.Threading.CompressedStack.Run(CompressedStack compressedStack, ContextCallback callback, Object state)
8: at System.Xml.XmlTextReaderImpl.OpenUrl()
9: at System.Xml.XmlTextReaderImpl.Read()
10: at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
11: at System.Xml.XmlDocument.Load(XmlReader reader)
12: at System.Xml.XmlDocument.Load(String filename)
13: at ECT.ECAD.API.WorksetConfig.RestorePartsDBVariables()
14: at ECT.ECAD.API.WorksetConfig.Restore(Boolean isWorkspaceConfig)
15: at ECT.ECAD.API.SystemSetup.RestoreNodeFromVariable(XmlDocument doc)
16: at ECT.ECAD.API.SystemSetup.Restore()
17: at ECT.ECAD.API.SystemSetup..ctor()
18: at ECT.ECAD.API.SystemSetup.Recreate()
19: at Bentley.Electrical.UI.Command.CommandEntryServiceBase.Init(Int32 hwndMode, Int32 hwndLayer)
Hi Andrew,Dose this Error Message come up when you launch Promis.e CONNECT or while opening a Project or doing any task ? Regards,Satish Saptasagar
When opening promise connect from the windows bar, or desktop shortcut.
I must've had some bad installation files from a previous install that my OneDrive was syncing with, I deleted both folders in ProgramFiles and ProgramData shut down OneDrive and reinstalled.... it's working now.
Hi Andrew,Thanks you for the update, good to hear that Promis.e is working. We dont recommend installing Promis.e CE Onedrive or storing the Dataset / Projects on OneDrive. Regards,Satish Saptasagar
Satish, if I want to work in the cloud, is ProjectWise only recommended? Thanks
