When I highlight a symbol and its related symbols and move the block together the line number reference data moves exactly two times further than the symbol data. The example above shows a sample set on the left and a moved set on the right that is moved up two grid positions. The line number data over moves in the direction of the move. For example if i move the symbol down and to the left 4 positions at an angle the line number data witll be down and to the left past the symbol by 4 more positions. This doesn't happen on all of my symbols but it does on some and I can't seem to identify what about the symbols are different. These are legacy symbols that we transfered over from Promis.e V8i.
This issue happens when I highlight a symbol by dragging a box around the symbol and highlight all of its elements and then grab the symbol and move it.
If however, I hover over the symbol body and allow the symbol to auto highlight and grab the symbol all of the data moves correctly.
The reason this is a problem is because I may need to move a plug and its 15 related symbols at one time and it jumbles the data all over the place.
I think this may be a check box somewhere or a setting. If you know any assistance would be greatly appreciated.
Satish,
I have created a SR 7001239605.
My Best,
Mark Allen
Electrical Engineering Tech
Promise CONNECT Edition Update 7 - Version 10.07.00.17
