Hi guys,
So, I've been trying to print the pages from my electrical project using the Print Manager.
Until this point, it's tottaly fine, I select the pages that I want and i go to the Print Organizer page. That's where the problem is. I can't fit the DGN pages correctly to print in the PDF pages. The image bellow shows this case. I ajusted everything right, according with the page style, size, etc (green boxes), but it still doesn't fit correctly. If I send this to print, it'll print exactly as you see in the red box, with the page cutted in half.
How can I solve this?
To make it even more clear, If I send this to print, it'll give me this:
The page 1 wasn't modified (I printed as the software gives me as default), the page 2 I tried to modify according with the figure 1 above.
Hi Matheus,For the issue you are facing can you try using Project Publisher for generating to PDF and check if it helps?
HTH Regards,Satish Saptasagar
Answer Verified By: Matheus Henrique
For now, it worked for what I need! Thank you!!
