How do you turn cross references on and off in Connect Series?
Hi Christoper,You can select the symbol first and then after selecting you will see "Show Cross Reference" options in Modify Component Ribbon. Select it to turn on /off the cross-reference.
HTH,Regards,Satish Saptasagar
Satish,
Toggling cross reference used to be in the right click menu. Is there a way to add it back?
Hi Lisa,Currently, in CONNECT you need to use the Modify Component RIbbon to use the Show Cross-Reference option. Regards,Satish Saptasagar
