Hello, I'm new to Promis.e connect and it seems the process of assigning wire numbers is totally different
now. What is the best way to assign wire numbers to a wire segment? When I click on a wire segment and
select "ADD WIRE LABEL" I see where you can check "ASSIGNMENT METHOD" as "Manual" but there's
no place to enter the desired wire number you want it to be. Is the Wiring Manager the only way?
Also, is there a way to place a copy of the wire number at the two ends of the wire segment?
Thanks in advance.
Hi Steve,You can assign a wire number to Wire after select by either selecting Wiring Manager in the Modify Wire Ribbon or by Right Click the Wire and select Wiring Manager. and then in Wiring Manager assign wire number.If you trying to assign Wire Label right-click on wire and select Add Label. Then select any point on the Wire when the Label Setting dialog comes up. Now you can double click on the Label to modify the text as per your requirment.HTHRegards,Satish Saptasagar
Answer Verified By: Steve Norcisa
Hi Satish,
If you have a wire and you have a wire number at one end, is there a way to place a duplicate wire number at the opposite end as well?
Best regards,
Steve Norcisa
Hi Steve,Currently, you cannot place two wire numbers on the same segment of Wire, but if you have multiple wire segments for the same wire you can place labels on the other segments as seen in the below image. HTHRegards,Satish Saptasagar
TY!
