Control C appears to copy without a basepoint. The paste is not on grid. Is there a setting I am missing?
Hi Lisa,It is a known issue in Promis.e / OpenUtilities Substation CONNECT with BUG#609600. And it will be fixed in the next release of Promis.e CE Update 9 if you are using Promis.e OpenUtilities Substation CONNECT CE Update 11. You can visit the below Announcement Forum Link to check for Release Updates of the softwares.
4. Go to the page where you need to place the symbol and paste it and you can now use the point specified to snap to the grid as per your requirement.HTHRegards,Satish Saptasagar
